[NEED HELP] LAPTOP STOLEN - NEED YOU !!! (Stairville + Expolite + Eurolite)
djserkande
FreeStyler Version: 3.5.7
Post by djserkande »
Hello my Friends,
last Month my Laptop and my dmx interface was stolen from my Car and i lost all the Fixtures. :|
That is very big problem for me you can understand... :(
Now i need your help, because i have a job next week. :!:
I need the Fixtures for following Light-Effects.
I have for you upload the manuals and pictures of the lights. U can download it below.
Last week i downloaded from a polnish website a fixture for mh x60 and payed for it 10 euros.
But the fixture doesnt work. So PLEASE help me to fix this problem.
1. STAIRVILLE - MH X60 (MOVING LIGHT)
2. EUROLITE - KLS5050 (LIGHT BAR)
3. EXPOLITE - TOURLED 42CM (LED SPOT)
4. EXPOLITE - TOURWASH 76 (WASH MOVING HEAD)
5. EXPOLITE - ELF24 (LED STRIPLIGHT) - Picture on Photo is correct. Pic on manual - No.
I have for you the Pictures and Manuals in Zip File.
http://www.djserkan.de/LIGHTS.zip
I will thank you after fix this problem with paypal. =) Trust me! ;)
:arrow: U can connect me over email to: serkanerkilinc( at )gmx.de
THANK YOU VERY MUCH. I'M WAITING FOR YOU
GREETINGS FROM STUTTGART :fs:
djserkande
Re: [NEED HELP] LAPTOP STOLEN - NEED YOU !!! (Stairville + Expolite + Eurolite)
Can nobody help me...???
FreeStyler Version: 4.1.7
Post by Rod_Horning »
I will try. This may take some time.
First one:
ExpoLite_Elf24_10chan.pff
(77.36 KiB) Downloaded 23 times
djserkande
Rod_Horning wrote: 25 Dec 2017, 18:45 First one:
Thanks men =) im waiting for you!!! =)
KLS5050
Attached are 2 fixture definitions. One will control both the 5 channel and the 20 channel mode. The other will control the 15 channel mode. Once you select the fixture(s) in the Freestyler workspace click on the top menu item Window -> All. This will display the Freestyler helpful programming windows (you may need to move them around a bit in order to see all of them).
For the 20 channel mode you will need to add 4 of the 5 channel fixtures for each physical instrument. Add all 4 using the number of fixtures field in the ADD/REMOVE fixtures windows. This insures that the channel numbers are assigned consecutively.
For the 15 channel mode, the Freestyler color segments feature is used. In the Color windows, in the lower left hand corner, you will see 4 check boxes. These correspond to the 4 physical lights.
Eurolite_KLS5050_15chan.pff
(42.7 KiB) Downloaded 23 times
Eurolite_KLS5050_5or20chan.pff
(25.49 KiB) Downloaded 24 times
Stairville MH-x60
2 fixtures. One is the 8 channel mode and the other is the 14 channel mode.
Stairville_MHX60th LED Spot 14chan.pff
(152.14 KiB) Downloaded 23 times
Stairville_MHX60th_LED_Spot_8chan_.pff
(122.04 KiB) Downloaded 23 times
TourLED42
Expolite_TourLED42_10chan.pff
(66.34 KiB) Downloaded 22 times
TourWash76
This instrument has 5 personalities. Which one do you want?
djserkande
Rod_Horning wrote: 26 Dec 2017, 06:14 TourWash76
U are the best Rod_Horning!!!
In Tourwash i need Person-1 please
Thank You ^^
TourWash76
Your feedback on these fixtures will be appreciated.
Good luck. Hope all works out well with your job.
Expolite_TourWash76.pff
(57.6 KiB) Downloaded 22 times
djserkande
Okay Rod_Horning,
very very very big thank you! Thats so good to see humans like you here.
Because this Lost is a big problem for me. I must buy everything again and this job is very important for me.
Thank you! I will Check the Fixtures tomorrow and give you information.
Thanks again!
Serkan ,-)
MAAC
Just started using FS
Post by MAAC »
Djesrkande
Do You know the word BACKUP ? Accidents happen and You are experiencing an effect of it !!
