Chauvet Intimidator Spot Duo 155 ?? Topic is solved
Djeargazm
Has anyone created the profile for the spot duo 155? It is different than the original spot duo. Thanks!
- FreeStyler Version: 4.1.7
Re: Chauvet Intimidator Spot Duo 155 ??
Attached are the user manuals I found. There are some differences in the colors, gobos and control channel.
Intimidator_Spot_Duo_QRG_Rev5_ML-8-_WO.pdf- (1.5 MiB) Downloaded 32 times
Intimidator_Spot_Duo_155_QRG_Rev1_ML9_WO.pdf- (1.46 MiB) Downloaded 36 times
