Bezier Shape Only Pan/Tilt
Motsik
Post by Motsik »
Hello, how can i make 2 bezier shapes only pan-only tilt ?
Also, is there any way to disable color mixing ?
FreeStyler Version: 4.1.7
Re: Bezier Shape Only Pan/Tilt
Post by Rod_Horning »
Please explain in more detail what you want to do when you say disable color mixing.
If you only want to pan or tilt then would not a 2 step sequence do what you want. The speed of the pan or tilt would be controlled by the scene scene/fade time.
