CLS led par56 GII fixture
dennisgamalej
Has mastered Fixture Creator
FreeStyler Version: 2
Post by dennisgamalej »
Hello everyone. Can anybody give me a fixture file please of a CLS led par56 GII. I was looking in fixture creator but its hard for me to understand it((( a will give in this message also a manual of this light. Thank you somuch
clsledpar.pdf
(675.12 KiB) Downloaded 29 times
FreeStyler Version: 4.1.7
Re: CLS led par56 GII fixture
Post by Rod_Horning »
Here is my attempt. Please test and provide feedback.
After you add the fixture to the Freestyler workspace click on the top menu item Window -- All
This should display the following windows:
Colors (should have 2 tabs: (1) Fixed colors (2) CMY- RGB
Lamp
Custom sliders
You might need to move the windows around in order to see all of them.
CLS LED PAR56 GII.pff
(66.64 KiB) Downloaded 27 times
dennisgamalej
hey) i tried it. It works bad. The strobe doesnt work. Colors are bad if i tap green i have blue.....
Please check the physical configuration of the light. I think you have it set to either 3 or 4 channel mode. The fixture I created is for the 6 channel mode.
