Showtec Kanjo spot 10
dennisgamalej
Has mastered Fixture Creator
FreeStyler Version: 2
Post by dennisgamalej »
Hello, does anyone has a fixture for the showtec Kanjo spot 10?
Thank you
FreeStyler Version: 4.1.7
Re: Showtec Kanjo spot 10
Post by Rod_Horning »
Attached is my attempt. I have no way to test it so please provide any feedback (problems, improvements, etc.)
After you add the fixture to the Freestyler workspace and select it click on the top menu item Window -> All
The following additional windows should appear (you may need to move them around a bit in order to see them all):
Gobos
Colors
Lamp
Custom Sliders
Pan / Tilt
This is a link to the manual I used: https://manualzz.com/doc/7365007/kanjo-spot-10-v1
Showtec Kanjo Spot 10.pff
(89.07 KiB) Downloaded 70 times
dennisgamalej
I want to buy this head byt i dont know if it works with freestyler
This appears to be a standard DMX controlled instrument using a 3 pin XLR connector. I can think of no reason it would not work with Freestyler. Make sure the voltage at your venue is correct for the instrument but that is a Freestyler issue.
dennisgamalej
I mean if this fixture works
