60W LED Moving Head Topic is solved
dj_h1988
60W LED Moving Head
Post by dj_h1988 »
hi
i need fixture moving head 60w ARC
Help me
FreeStyler Version: 4.1.7
Re: 60W LED Moving Head
Post by Rod_Horning »
Please either upload a PDF of the user manual or a link to the user manual. It may also be possible if you upload photographs of the DMX channels. As much as we would like to help we do need some information in order to do so.
dj_h1988
Post by dj_h1988 »
1.zip
this attachments dmx chanels
Attached is my attempt. Please test and provide feedback. I will change the fixture if you note any improvements.
The documentation says this instrument has 18 channels. The document only lists 16 so I do not know what function channels 17 and 18 perform. The fixture will control channel 17 and channel 18 via the standard FREESTYLER sliders.
Also the documentation references channel 17 as controlling channels 12 and 13 but if you read channel 15 it appears to provide this function. The macros I coded assume channel 15, if this is incorrect they can be changed.
After you add the fixture to the Freestyler workspace and select it, click on the top menu item Window --> All.
The following additional windows should appear (you might need to move them around to see all of them):
Colors
Lamp
Custom Sliders
Pan / Tilt
Macros
(the grey boxes control the channel 12 static effect show. The black boxes control the channel 13 dynamic effects show)
dj_h1988
Post by dj_h1988 »
hi
tanx for fixture . but not work :(
i attachment a User Manual for my moving head for change the fixture
Moving Head 60w ARC - Spark.rar
Based on the pictures in the Spark.rar file I've changed the fixture.
