I have 4 of these.
https://www.amazon.com/gp/product/B071K ... UTF8&psc=1
Pan and tilt works great, just no color. I've read through every Wiki article that seems relevant. I just cannot figure out what I'm doing wrong. Also not sure what to do with channel 5 - "Speed". I've attached my fixture file, and a picture of the DMX Values from the manual. HELP?
Peter
Mini LED Moving Heads - Cannot get colors working
petemcknz
- FreeStyler Version: 3.6.4
- I Use FreeStyler for: Band
UKing_Moving_Head.pff- (3.09 KiB) Downloaded 41 times
- FreeStyler Version: 4.1.7
Re: Mini LED Moving Heads - Cannot get colors working
Do not see the DMX values picture and I am unable to find an online user manual.
If I looked at the correct instrument it is a 14 channel instrument - the fixture file specifies 13 - could channel overlap be your problem?
In Freestyler click on Output -> Show Output. From the resulting window verify the channels have the expected values.
The instrument has 2 or 3 modes. Wouldn't hurt to check that DMX mode is selected (I assume it is since you state that pan / tilt works).
Without the user manual I can't be sure but my guess is that channel 5, speed, controls the speed of the pan/tilt movement.
Update: I also noticed that the Shutter Channel defaults to closed
petemcknz
Looks like I got them working with a similar .pff --- attached
I didn't realize Lamp and Intensity were the same. Channel 5 was Pan/Tilt speed.
Now I need to figure out how to make sequences work. Thanks!
12 Watt Cree Beam.pff- (4.46 KiB) Downloaded 40 times
