Marq gesture beam 400 Topic is solved
roger537
hello i need a fixture for a Marq gesture beam 400. i included the user guide for anybody that wants to help me out.
Gesture Beam 400 - User Guide - v1.5.pdf- (4.82 MiB) Downloaded 41 times
- FreeStyler Version: 4.1.7
Re: Marq gesture beam 400
Attached is my attempt.
Once you select the fixture click on Window -> All (top menu item). In addition to the normal Freestyler sliders window this will open the following windows:
Gobos
Beam
Colors
Lamp
Macros
Custom Sliders
Pan / Tilt
You might need to move the windows around in order to see them all.
Hope this helps.
Feed back will be appreciated.
Gobos
Beam
Colors
Lamp
Macros
Custom Sliders
Pan / Tilt
Hope this helps.
Marq_GestureBeam400.pff- (82.23 KiB) Downloaded 44 times
