BAX iDance PAR12-247 RGBW (8 channel)
siggy019
Post by siggy019 »
...one of my first selfmade fixtures ;)
Maybe there are similar products on market, but most of them have different channel configuration.
Not every variation is saved as macro.
Feel free to add some comments or improvements.
jkoller
FreeStyler Version: 3.2
Re: BAX iDance PAR12-247 RGBW (8 channel)
Post by jkoller »
Hey man, thanks for submitting.
But i cant get these to work. Do you know to what settings i should set the lights?
FreeStyler Version: 4.1.7
Post by Rod_Horning »
If the physical instrument is configurable then it must be configured to DMX mode and 8 channels.
In the Macro window you may need to click on the 100% macro - I am not sure. Of course the dimmer channel must be set high enough to see light and at least one of the RGB channels must be set high enough also.
jkoller
Post by jkoller »
Got it figured out, thanks!
siggy019
Post by siggy019 »
Yeah this part is cheap but hot ;) I have ordered some more after testing ;D ... changed some little details
