Generic FTDI chip based interfaces
- FreeStyler Version: 3.643
I bought some FTDI chip based (FT232RL) based interfaces, making USB to serial conversion. Then a MAX485 RS485 chip acts as DMX line transmitter.
In Windows there will be a USB to serial converter in device manager.
It seems there are a lot of those cheaper interfaces using the FTDI chips, so I wonder if there are some setting for 'Generic interface' in Freestyler setup?
I tried to use the Eurolite USB DMX and it seems to 'work' somewhat but should be better to know.
Re: Generic FTDI chip based interfaces
You should use the "Enttec Open DMX" setting.
How may of these interfaces do you bought? Only one? Maybe two of them?
Also do not forget (if necessary) to install FTDI drivers. May not be necessary. If you computer has used some FTDI FT232RL chip in the past -like a USB to Serial converter- your computer should had installed drivers for it before.
Thanks. It worked.
I bought 4 of those interfaces and I will add isolation to them also.
What happen if you connect two, three or all four interfaces to your PC at the same time? Do Freestyle setup treat each interface as a distinct unit? If so, you could assign different unverses to each interface. I will do tests next week (since I am still soldering the PCBs) but if you already have several interfaces at hand, it would be very useful if you test that. At least Jinx! software treat each interface a a disctint unit (it is recognized by its FTDI serial number; something like "F67JYU8" for example; every FTDI chip has a different number).
Regards.
Regards.
Could you share for example screen captures of the FreeStyler setup showing several interfaces?
I can check tomorrow. And I will share some screenshot of setup.
But I guess there will be possible to add one interface per universe, since this is already support from setup.
Unfortunately I was not able to get two interfaces working in one universe each.
Freestyler failed to init two interfaces at the same time.
At some point, I managed to get two universe out by selecting Eurolite USB-DMX on one channel and Enttec open DMX on the other.
But it was hard to get it up and running.
Very interesting (and thanks for your time to make the tests). As soon as my interfaces will be finished I will also test them and post results. Using Jinx! software I was able to connect two Enttec Open DMX and asign different universes to each. I do not know if other software can accepth this setup (Madrix, Glediator, etc.)
I have designed a new interface which I will build and test very soon.
It's an isolated interface using FTDI chip.
Post results later on.
- FreeStyler Version: 1024
Hola tengo una placa adaptadora usb a RS485 la cual la he comprado a distintos proveedores y noto que una solo emite señal dmx con polaridad invertida y otra con las dos polaridades de señal... por qué sucede esto? Se puede modificar? Gracias
