Hey,
I'm looking for a fixture for the MAX PARBAR
https://www.maxiaxi.com/max-parbar-met- ... en-remote/
MAX PARBAR Topic is solved
- FreeStyler Version: 4.1.7
Re: MAX PARBAR
Please give the attach fixture definition a try. Feedback appreciated.
After you select the fixture in Freestyler click on Window All (top menu item). This will open several windows (you may need to move them around in order to see all of the windows).
MAX_PARBAR.pff- (6.96 KiB) Downloaded 29 times
