1...30 channel fixtures to get you on your way....
The Purpose of the below fixtures are so that you can in an instant add them to freestyler to get control over any lights you have that dont have profiles for them yet or if you'd like to create a fixture profile but dont have a manual to hand.
  • To use them download the correct fixture to your computer (you can usually find out on the case or the manufacturers website how many channels your light uses).
  • Double click them once on your computer then this will add them under the manufacturer 'TEST FIXTURES' inside FreeStyler
  • DMX Address your light to the same as you have set when adding the test fixture
  • Now you can select teh fixture and use the sliders window on the right of your FreeStyler screen
A Note : If your new to creating fixtures this will help you understand using the Fixture Creator and learning what values you'll need to add to Fixture Creator to build a profile
More Fixtures Added Soon!
BillDavidson
Re: 1...30 channel fixtures to get you on your way....
Post by BillDavidson »
THANK YOU!
No woories it says 1-30 channel fixtures but i lost interest at 7 I must try to finish it all off!
lesena
Post by lesena »
You can help to create fixture files (Lemon Led spot 10) ? A thousand times I tried did not work and looked FS Wiki.
Here are two references to himself arrived, and you can download the manual.
http://www.asiamusic.ru/catalogue/produ ... 3048623742
http://www12.zippyshare.com/v/24759512/file.html
The reason we say your the best person to make the fixture is because we can't test it and if you tested it then suggested improvements we havent got all the time in the world to make fix it! Going on what you have given me I've knocked up a fixture if it doesn't work I can't help you... there are no colours just colour numbers as I do not know what the colours are if you feel like adding the colours mark them down then open fixture creator and change the images its easy to do I also recommend you look at the fixture in fixture creature then look at your manual to SEE how it is done then you do this thing called 'learn' when you 'learn' you can make your own fixtures so easily!!
Post by Jan_K »
You two are messing up the thread :(
@ djsupport: Lazy you. ;)
Here are 32 generic fixtures 1 to 32 sliders in the right side of FreeStyler.
Generic.zip
Tidy it up then mod ;-)
