Elation ACL 360i Topic is solved
Tyler
Elation ACL 360i
Post by Tyler »
I need a profile form the elation ACL 360i, the one I made for some reason, like to sporadically move.
Any help would be greatly appreciated.
FreeStyler Version: 4.1.7
Re: Elation ACL 360i
Post by Rod_Horning »
Please export your fixture for your ACL 360i. Attach the exported fixture file to this thread.
What DMX interface are you using?
Make sure there is no channel overlap. If another fixture has a channel that is the same as any of the channels that control the pan / tilt of your 360i this would cause unexpected movement.
Is your DMX circuit terminated properly? If not this could be your problem.
Are you using DMX cable or microphone cable? They both use XLR connectors. While microphone cable can work it can also cause problems.
Another possibility, though slight, is a spurious signal induced by induction due to a 120V/240v electrical supply line running parallel with and very close to your DMX cable.
