ADJ Inno pocket twins fixture?
Tupsy
Post by Tupsy »
Hi all.
I have just bought 2 set of the Inno pocket twins.
Have anyone created a fixture for this?
I have tried to search for it but with no luck. :-(
Regards
Tupsy
FreeStyler Version: 4.1.7
Re: ADJ Inno pocket twins fixture?
Post by Rod_Horning »
Hello Tupsy.
Did you find, or create, a fixture (or fixtures)?
If you still need them let me know and I will see what I can do. (Please verify the following link is the correct instrument: https://www.manualslib.com/manual/93546 ... =15#manual)
tbA
Post by tbA »
Did anyone create a fixture for this?
Post by Jan_K »
Hej
Here is a draft. The gobos are only numbers so please fill in the images which fits and upload it here again.
The fixture is to be set in 20 channel mode.
The fixture file is created as a 10ch file and are to be added twice, one for each spot to cover all 20 channals.
American_DJ_Inno_pocket_spot_twins_2x10ch.pff
(80.36 KiB) Downloaded 32 times
