Which kind of grease use to refurbish our DMX fixtures?
Barabba
Post by Barabba »
Hi all here! Thank you for kindly report your experience.
Does anyone here fixed/refurbished a DMX light?
I'm going to replace the LED chips on 6 scanners after 5 years 24h working, and I would like to add come grease to the mechanical parts too, may you kindly suggest me which kind of grease should I use? There are different types.. as I read I guess Silicone spray is better than CRC 5-56 or WD40 which by the time/hot can become "gum"..
I would like to use a spry to be able to reach difficult parts without unmounting all. Thank you for you kind help
Barabba
Re: Which kind of grease use to refurbish our DMX fixtures?
Post by Barabba »
Alternatively I can use oil for car engine, synthetic.. what you think?
MAAC
Just started using FS
Post by MAAC »
Molycote is what is being used in video recorders and tape deck gears
danmcr
FreeStyler Version: 3.6.50
Post by danmcr »
I have a couple of moving heads that squeak when moving. I'm assuming this is due to a lack of lubrication. Any suggestions?
SiGNe
FreeStyler Version: 4.14
Post by SiGNe »
For gears you need a more thicker lubricant, not a liquid one.
Like MAAC said, Molycote is a good one.
xever
Twitter: www.120db.uk
Post by xever »
Look for a specific grease for what you intend to lubricate, plastic gears, or metal bearings.
Stay away from CV grease as these are intended for heavy loads and high-pressure joints and rollers.
I typically use white lithium grease.
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
danmcr
Post by danmcr »
Thanks for the suggestions.
