In an earlier version, using submasters and the cuelist, I was able to switch to different sequences in the submaster and my cuelist preferences (disable fade, react to sound, loop, etc) would be maintained.
Now, in 3.6.43, my cuelist preferences are reset. Not sure if this is a bug or if there is a preference somewhere to maintain existing cuelist preferences (disable fade, react to sound, loop, etc)
My current workaround is to select the new submaster sequence and manually reapply the cuelist preferences.
Any thoughts/suggestions? Is this a bug or is there a preference for this?
CueList not maintaining prefrences
- FreeStyler Version: 3.5
- FreeStyler Version: 4.01
Re: CueList not maintaining prefrences
Mine works fine, I dont use submasters but I do use Cuelists and the values are saved. You may try resetting those attributes then hit quicksave for each cuelist and see if that helps.
@partyman, thanks for the reply. When only using Cuelists my preferences are maintained, however, when "running" different submasters, which alter the Cuelist, the preferences are reset.
- FreeStyler Version: 3.6.4
hi, i have the same problem.
have you resolved it?
