First have you tried? Log in to Search the Forum for help! Learn more about using FreeStyler at the FreeStyler WIKI HERE
Please do NOT post bugs here! If you spot a potential Bug please report it HEREfirst then you can chat about it with other users in the appropriate section.
Hi.. first of all sorry for my english..
I've tried to set up 2 moving heads (stairville mh-x25)
with freestyler through a usb/dmx interface (usb-dmx512)..
I've got a stairville lighting mixer too.
At this moment nothing happens when I try any command on software..
Thanks!!!
1) is your USB to DMX device connected and recognized
2) Hook up 1 fixture on channel 1 and use it to make sure all is functioning correctly before adding additional fixtures
Not sure what dongle that is or what the problem is but until you get rid of that error nothing will work. Make sure you have the correct dongle selected and that alll drivers are correct
Thanks a lot! I've tried to re-install correct driver and a software to test it.. it seems all works.
I think the problem is when I'm looking for the interface name on Freestyler/setup. I don't find the same name (KMTronic USB DMX512).
Either that device is not supported by Freestyler or it is listed under a different name. Until you straighten this out nothing will work. I would suggest getting an Enttec dongle and be done with your problems
Thanks Partyman! I think now is all right!
When I was looking for info about my device, i've seen this:
"Run FreeStyler and in Setup>FreeStyler Setup choose "Enttec open DMX"
Thanks a lot for your kindness and hope to improve in lighting..
