slimbeam quad Irc qrg Topic is solved
dancoleman89
Hi, Any ideas how to make this on fixture creator?
SlimBEAM_QUAD_IRC_UM_Rev1_WO-1.pdf- Manual
- (823.34 KiB) Downloaded 16 times
- FreeStyler Version: 4.1.7
Re: slimbeam quad Irc qrg
As with similar fixtures it seems the best way to configure this device is to create 2 fixtures: (1) for the control functions (2) for the LEDs.
When you add the fixtures to Freestyler you will add 3 LEDs and 1 controller.
Choose your starting address for the instrument (the attached fixtures are for the 16 channel configuration)
Add 3 LED fixtures specifying your chosen starting address
Add 1 Control fixture specifying the starting address 12 higher (ie. if the first LED is addr 001 then the controller is address 13).
When you select the controller or any of the LEDS be sure to click on Window All.
If you have selected an LED the Color window will appear
If you have selected the controller a Macro window will appear.
Do not select both the controller and an LED. If you do then not every window will appear.
In the Macro window the first set of macros control channel 14 and the second set control channel 16. Of course you can also control these channels with the normal sliders.
SlimBeam_Quad_IRC_control.pff- (40.42 KiB) Downloaded 15 times
SlimBeam_Quad_IRC_LEDs.pff- (2.87 KiB) Downloaded 14 times
