what is the best way to organize sequence and cue files? Topic is solved
perrip
- Commited FS Forum helper
- FreeStyler Version: 4.6
Hey so sorry for another probably obvious question, but what is the best way to organize your sequence and cue files, for having multiple location files ( I have some setups that use totally different fixtures)? Since Freestyler default puts them all in the same place. And as part of this question, can you after the fact put your sequence and cue files in newly created folders, or is Freestyler always working off where the file was first saved to when you made it? Like if you put your sequences in a new folder will you cues not work?
- FreeStyler Version: 4.01
Re: what is the best way to organize sequence and cue files?
You can reuse sequences as long as addresses are the same. You can also move sequences but beware if they are part of a cuelist or saved location. I create a Location folder then a folder for each fixture type inside of that. You can also save and open various location files with different setups
perrip
Hey Thanks so much, I should have started out doing that, but not a big deal, I just will going forward, Thanks for your help!
