Hi there, I have made several sequences - they are only basic as I only have 2 LED Par Cans, but I have various colour patterns and they all work well.
I don't know where to go from here. I am the drummer in a band and I want to be able to easily switch between sequences or to have them automatically cycle through ALL the various sequences.
I have tried adding the sequences to the CUE window, but it will not let me do this... When I click on 'insert sequence', it just opens it up in the editor which then goes into 'OFFLINE MODE'
Where am I going wrong?
Is there a better way to display my sequences which I can just easily select them whilst we are doing a gig? I'm running a laptop next to me whilst we play...
If you can point me in the right direction I'd be really happy
Cannot insert sequence into cue...
RobbieC
- FreeStyler Version: 3.6.4
- I Use FreeStyler for: Band
T0NIT0 RMX
Re: Cannot insert sequence into cue...
Hi !
If you have less than 20 sequences then the best thing to do is to put all your sequences in the cuelist and then asign a shortcut to every sequences, like press "numpad1" load sequence 1, "numpad2" load seq 2 and so on !
So then you will just have to hit the shortcut you set to lauch the sequence.
Automatic cycling between sequence is not possible afaik, but you can randomize step sequences if you want (just check the option, the wiki explains it)
You don't need to use cuelist buttons, but if you want to use them, just right click on one of them, that will make a window appear, with 20 sequences slots, put your sequence in it and save as the name of your choice, then when you it the cuelist button it will load the sequence (you can add shortcuts for it also).
But really, if you just have singles sequences the easiest way is just to use the cuelist !
Let me know if that works !
Best Regards.
- T0NIT0 RMX
Facebook : https://www.facebook.com/t0nit0rmx
Soundcloud : https://soundcloud.com/t0nit0rmx
Youtube : https://youtube.com/t0nit0rmx
Twitter : https://twitter.com/T0NIT0RMX
- T0NIT0 RMX
