the new kmx freestyler dmx iphone app Topic is solved
Djtomdmx
Keibir
- FreeStyler Version: 3
Re: the new kmx freestyler dmx iphone app
Hey Djtomdmx - it should be really easy:
1. the computer and the ios device are in the same network?
2. you need to know the IP-Adress of the computerwhere freestyler is running
3. you need to let freestyler through the firewall of the computer
4. open KMX on your iOS device and enter in the first field the IP like: 123.456.789.123
and in the second one the Port of freestyler which is if not changed: 3332
and click on "Verbinden" (i will translate this - i forgot
danielo erre
Esta aplicación m
Kmx remplaza a la anterior freestyler remote dmx? Osea hacen lo mismo?
Keibir
Please write your request in english.
ryanbaileytech
hi guys,
im very new to this software as a potential solution for "ambient" lighting. can you please let me know if there is a color pallete cmy/rgb feature in the app.
thanks
thanks
Keibir
Hello Ryan,ryanbaileytech wrote: 24 Jul 2019, 07:20 hi guys,
thanks
i implemented the normal color sliders ( R, G, B ) and also a pallete Picker under theese sliders. When i am at home i can send you a screenshot.
Best Regards
ryanbaileytech
thanks,
i have gone ahead and downloaded this but having problems to connect
i get the error (TCP-Socket)
please help
please help
Keibir
Which Freestyler Version do you have?
Are you mobile Phone and the PC in the same Network?
Did you put in the right IP(your PCs IP running freestyler)?
Did you put in Port 3332 like the Manual of FS says?
Did you let FS through your firewall?
ryanbaileytech
freestyler 3.6.49
ios 12.3.1
same wireless network and allowed windows firewall through..
ip address im guessing is ipv4 in ipconfig..
ios 12.3.1
Keibir
Okay
yes you are right - its the ipv4 configuration
do you see a Freestyler Icon inside of freestyler in the upper right corner?
ryanbaileytech
i have just turned off windows firewall and now i see the icon... but still no luck
ryanbaileytech
and now i have clicked disconnect all and lost the connection icon again
Keibir
Okay - now there is a connection. But the app is missing something i guess. If you send me your acutal Cuelistconfiguration; Cuetabs and Buttons - i will try to reproduce your problem.
If i publish a new version, i test all of my configurations. But there can allways be a configuration i didn't thought about,that make problems.
Keibir
KMX 4.1
https://youtu.be/vyu9z3kOVHI (just a quick not professional demo...)
- ios13 ready
- "search FS in local network"-function implemented
- bugfixes and improvements
- small hint: do not use § in your Buttons/Cues/Lists..-names
=> in check by apple; comming soon online
- ios13 ready
adeerr1
- I Use FreeStyler for: Band
Hello,
Kmx app is No longer available in AppStore,
Is there any chance to Put in again?
- djSupport
I don't think the developer continues with this app, only the Android app is actively developed
SiGNe
- FreeStyler Version: 4.14
Its part of a new policy by Apple, if an app doesn't get regular updates it's just removed by Apple, even if the app is working fine.
Personally i'm glad i have an Android phone, Freestyler Play works great
xever
- Twitter: www.120db.uk
And the problem with Apple is you need the latest Mac to use the new developer tools, just to target the latest iOS.
My Android App is built on a 5-year-old PC that can still target the latest version of Android.
I started to build an iOS app but Apple would not allow me to publish it without updating my Mac to the latest OS which it wouldn't support,
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
www.120db.uk
- djSupport
Apple are such charlatans, why do people keep getting mugged off by them...
