Chavet Shadow and LED TechnoStrobe(white)export files needed Topic is solved
djwikkid
Post by djwikkid »
I am new using freestyler and cant believe sucha nice program is open source. As soon as I complete my installation and like it even more, I will be making a donation, as should everyone else that uses Freestyler.
I am looking for the files for the LED Shadow and LED TechnoStrobe, the all white one.
The DMX configs are the same, but I'm trying to figure out how to be able to set the different values for the autoprograms on channel 1. So if someone has them, please email them to me at djwikkid@tampabay.rr.com and if you can, give a brief explaination on how that works with indexed settings on one channel. Then I'll know how to do it myself after that and be able to contribute more to the forum here.
My thanks in advance,
WIKKID
djwikkid
Re: Chavet Shadow and LED TechnoStrobe(white)export files needed
Post by djwikkid »
Or if anyone can explain how I can get indexed functions set as presets I would greatly appreicate it.
use the macro function then make a few little pictures for the macro buttons to explain the functions in the macros...
