Where to download?! (can only find beta!) Topic is solved
discoadz
Post by discoadz »
Hi All!
Have looked through site - but can only seem to find a download for the beta. Every time I download, it seems to be file "setup296j" - which is the beta(?)
Any suggestions?
many thanks!
adam
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Where to download?! (can only find beta!)
Post by Mattotone »
2.96j is the current version, even though still in beta.
It sorts out a few bugs from previous versions.
Matt
the technically stable release is downloadable from the forum frontpage above the beta version but most people use the most current beta unless your pc works better with older releases...
