HELP! Subscript out of range???????????? Topic is solved
Djsynystr
Post by Djsynystr »
heres my problem. i have installed freestyler on another laptop that i want to now use for frstyler and i went and copied all of my gobos, fitures, colors, cues etc from the main laptop onto the new one. all the cues open in fs but when i go to run them i get a "Subscript out of range" message then i have to click ok before it starts to run. when i click on show output nothing happens, meaning no show output window pops up with the info i need. did i not copy the files right. is there something i need to do or not do when trying to duplicate settings on two machines. please any ideas or help would be great.
Re: HELP! Subscript out of range????????????
are they both running the same version?
Djsynystr
Post by Djsynystr »
yeah disregard post. i did some searching and found the post regarding restore/backup which i did instead of coping each folder/file manual and it worked fine. i knew there had to be a simpler way than manually coping folders from machine to machine. once again freestyle is a great product!!! thanks for the fast response.
no worries
Djsynystr
Post by Djsynystr »
i keep getting this message again when i try to use any of the shapes in Pan/Tilt it say "subscript out of range" as soon as i click on ANY shapes. is there a way to check the dmx address of the cues etc i made? i believe the problem to be i have added or changed fixtures since making them all up.
FreeStyler Version: N/A
Post by remco_k »
What version of FS?
Please check your fixture file(s) if all mandatory fields (they are in bold) are filled in correctly.
