eyourlife Digit PAR Light RGB Topic is solved
Murtman24
FreeStyler Version: *
Post by Murtman24 »
hi there i have created this fixture however the 6th channel is a Master function and i do no where to put this in the fixture creator, can anyone help i have a manual and the fixture that i have created,
Chris
Re: eyourlife Digit PAR Light RGB
Post by Jan_K »
Hej Chris.
Please upload the manual and eventually the fixture file so we can have a look.
Murtman24
Post by Murtman24 »
Please Find attached
Spot.pff
Fixture
(4.4 KiB) Downloaded 34 times
18x3-Par-Light-Manual (1).doc
Manual
(173.81 KiB) Downloaded 22 times
Murtman24
Post by Murtman24 »
Post by Jan_K »
Hej.
I see your problem. There is no information of what "Master function" does.
First you need to change "Total Channels" to 6.
Your fixture listen on 6 channels and you need to reserve 6 channels even if you don't use them at all.
You then need to figure out what the "Master function" does.
You can use the sliders in right side of FreeStyler or you can assign the Master Function to a "Custom slider".
You then adjust the first 5 sliders to lets say 50% / 127.
And then you start to change the Master function slider slowly.
Each time you see that par can changes or does something new you record these values.
And when you have a list of these functions / values you can add them as macros.
