Hello,
Is it possible to make a cue in the cue list not to react on the tap-sync?
I want to run a slow and a fast cue at the same time, the slow one with the previously programmed speed and fade time and the fast one with the tap-sync speed.
Thanks for your help!
Tom
Make a CUE to NOT react on the tap-sync Topic is solved
- djSupport
Re: Make a CUE to NOT react on the tap-sync
I guess you'd have to tap for the cue you want to tap to and then untap it on the one you donn't...?
