Enttec DMX Open USB or another ?
Jaykie
Post by Jaykie »
This is from the old forum
Sybux
I'm looking to buy an Enttec DMX Open interface but I can't find local reseller (I only find the manufacturer in Australia). Is there a local reseller in Europe, idealy in France ?
Second question : is the Enttec a good solution or is there a goos alternative at a low cost also !
Thx
DJ SUpport
yes its good yes it will do everything you need it to do and it sends dmx processed from your pc rather than an internal processor so you need to have a fairly good spec pc to run it without any problems.
http://www.enttec.com has a list of dealers I know theres a few in the uk if you cant find one in france shipping just across the pond should be cheap and quick!
Return to “DMX Interfaces”
