ELC 250WATT MINI NEO-ONE SRM 25007 Topic is solved
che81
che81
Re: ELC 250WATT MINI NEO-ONE SRM 25007
I have Manual. But can't create a fixture in Freestyler. Hope that someone helps me
Nathanrs93
- FreeStyler Version: None
Please upload the manual, otherwise you'll not be able to get help for the fixture.che81 wrote: 05 Jun 2017, 20:29 I have Manual. But can't create a fixture in Freestyler. Hope that someone helps me
- FreeStyler Version: 4.1.7
I don't know if you still need this or not. If you do please give the attached a try.
After you add the fixture to the Freestyler workspace and select it click on the top menu item Window -> All. This should open the following additional windows:
Gobos
Colors
Lamp
Pan/Tilt
The manual (also attached) did not specify which way the color wheel rotated so I may have the colors reversed. If so let me know and I will fix the fixture definition.
Feed back appreciated.
Gobos
Colors
Lamp
Pan/Tilt
srm25007.pdf- (225.77 KiB) Downloaded 18 times
ELC MINI NEOONE SRM 25007.pff- (36.39 KiB) Downloaded 16 times
