FreeStyler X2 3.6.0.40 does not work correct with ArtNet.
You can't Access Universe > 3
Net and SubNet addressing works properly BUT Universe adressing Fails.
If Universe >3 then the nodes will disconnect from the ArtNet.
and several other Problem.
Here Comes a detailed short list:
Net, SubNet, Universe
0,0,0 wokrs properly
0,0,1 works properly
0,0,1 will also received @ node site 0,0,2
0,0,2 works ok
0,0,3 Woks ok
0,0,4 ... 0,0,15 NO ArtNet any more
Net and SubNet works correct, just the Universe Setting failes
Tested with several PCs under Win 7 & 10 No Firewall, No Wifi Just ArtNet LAN
ArtNet Topic is solved
- buttza
- FreeStyler Version: 3.6.4
Re: ArtNet
Isn't Freestyler only a 2 Universe software though?
- djSupport
- buttza
Re: ArtNet
Hahaha.
lj_raph
- FreeStyler Developer
- FreeStyler Version: 3.2.1
Re: ArtNet
Indeed, there is a bug in the Art-Net module that gives some issues when selecting other universes.
A new beta is available for you to test. Send me an email freestylersupport@telenet.be
Raphaël
