I want to control several Chauvet LED Shadows. To my chagrin, despite a long list of lights, this wasn't there under Chauvet. Bad start- the ONE light I own isn't listed!
I chose what appeared to be the closest- Chauvet UV shadow. I have a feeling that product may be analog, but I'm not sure. The icon sort of looks like mine though.
I seem to have a little bit of control but not much.
The LEDTrix and Suntrix seem to have no control. I tried all sorts of settings- nothing works.
The MUSIC macro takes them from black, to a walking line pattern but it's not sensitive to sound. The window shows the sound levels going up and down but, lights don't react. I added several pattern-macros like spirals but they don't seem to work with the LED shadows.
The LAMP window does the most- it will DIM from full to off, and the lightning-bolt control speeds up or slows down the walking pattern.
Can someone get me started with sending patterns to the LED shadows, one at a time (one on chan 1, one on 4 right now)? Like spirals, dim-to-bright, etc.
I've done a lot of reading , watched Youtube tutorials, etc. But there seems to be little to nothing about the LED SHADOW control.
Any other advice is most appreciated.
