Hi Everyone
I'm in search on a fixture profile for the Beamz Panther 25 Spot light.
I've given it a shot but somehow it's not working
I've also attached the user manual
BeamZ Panther 25 Fixture Topic is solved
Gizmo
Beamz Panther 25 LED - manual.pdf- (1.51 MiB) Downloaded 56 times
- FreeStyler Version: 4.1.7
Re: BeamZ Panther 25 Fixture
Hello Gizmo
Did you solve your problem?
If not please export your fixture profile and attach it to this thread.
elementfire9888
Can Anyone please submit this? Because we would like to use this in Freestyle.
Attached is my attempt for the 11 channel configuration.
The following helpful programing windows are available (top menu Window -> All)
Beam
Color
Macros
Pan Tilt
Custom Sliders
Beam
Color
Macros
Pan Tilt
Custom Sliders
BeamZ_Panther_25_LED _spot_11ch.pff- (82.45 KiB) Downloaded 85 times
elementfire9888
Rod_Horning,
Thank you for uploading the Fixture profile. I have only one problem, after added the fixture the panther 25 goes in the autmatic mode.. doens't react anymore and i have to close the program (Freestlye) in orde to reconnect the panther 25..
What I do when add the fixture profile: Setup - add/remove fixture profile - BeamZ - panther 25 settings start at row 1, fixture to add 1, DMX Universe 1, DMX startaddres 1, add fixture to zone 1. After that the Panther doens't react to any commando's.
Panther 25 DMX addres: 1 all normal nothing has changed
Converter I use: Velleman USB controlled DMX interface vm116/k8062
What do i wrong? Please Help me
Do you have the physical instrument configured in 11 channel mode? The fixture profile will not function as expected if your physical instrument is not configured in 11 channel mode.
The user manual seems somewhat adamant about terminating the DMX cable. Copied from the user manual: At the last fixture, the DMX cable has to be terminated. Solder a 120 Ohm resistor between signal (-) and signal (+) into a 3-pin XLR connector and plug this into the DMX output of the last fixture in the chain.
If you only have the one fixture and the cable length is not long I doubt this is the issue but, with this instrument, it is a possibility.
Would you please explain in detail your statement, "... the panther 25 goes in the automatic mode." What does the instrument do?
