Hi, first I tried the bug tracking system, as someone else reported it will not let you enter a bug because it says "Progress is not filled in", there is no Progress field on the web page.
So I have tried to use the Artnet2DMX from version 3.6.40 with my Enttec pro dongle and have found it will not select that, it will select the Enttec open dongle and the Espilon ones though. When choosing the Enttec pro from the drop down list if never shows the com port selection drop down menu. If you type in "Enttec Pro" it sometimes will show the drop down. and you can save by using the file / exit menu. If you exit by hitting the X in the top right it most likely closes the window but part of it hangs in memory and prevents it being opened again.
PC, WIn 10, Enttec Pro
Thanks, Anij
ARTNET2DMX ENttec pro bug
An1j21
- FreeStyler Version: 3.6.4
