Gobo spin in Visualizer
- Shannon D
- FreeStyler Version: 3.3.2
- I Use FreeStyler for: Band
I need help with making gobos spin and multi colos in the 3d visualizer. I created Chauvet Q-Spot fixture file using ScanLibrary and after a while, I got all the gobos and single colors work fine. Hint, if you change anything in the fixture file, you have to delete the fixture from the visualizer, then add it back in. I wanted to try another fixture to see if the gobo spin worked, so I added the Martin Mac 500 and the gobo spin works fine. I went back into ScanLibrary and setup the Q-Spot gobo rotation exactly the same as the Mac 500 (except dmx values), but it still won't work. What's wrong? Also, how do I get multi colors (split colors like blue/yellow) to show up in the visualizer?
