SPD SX controlling cuelist Topic is solved
rizlfrizl
Im having trouble understanding why im Roland SPD SX wont toggle through the cuelist. I am able to map midi notes using the"learn" button under settings/externalcontrol/midi. I am able to see the note information populate as i hit different notes. Any information would be greatly appreciated.
rizlfrizl
Re: SPD SX controlling cuelist
Ive spent some time looking into the issue and have discovered the following:
Midi signal is reaching freestyler with channel and note number and 0 velocity.
and midi commands occur (change the cue list) when i hit the pads very very hard....
is there a way to lower the threshold for this trigger?? I dont want to blast these pads every time i want a light change
rizlfrizl
download Freestyler Configuration tool. Set velocity to one and point at root Freestyler folder location. Everything now works perfectly.
mattspunkm
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
- Twitter: twitter.com/mattspunkm
we are wanting to use complete backing tracks with spd-sx... we are also wanting to control different light cues within each backing track using note on/off... is it possible to do this with spd? At the moment, we are using an ipad to play backing tracks.. what ipad sequencer should i use to playback tracks AND midi notes to trigger freestyler cues to my pc?
