Chape generator no longer equal
daantas
Post by daantas »
Hello,
I have 4 MH.
if I select them all and I click on the on / off of the generator shape, then move the lights after a few seconds no longer equal
Is this a bug or am I doing something wrong
The MH that I have selected as last, runs as the first unequal
I have the MH in a different order selected and each time it is another MH which first runs unevenly
Each time that the MH whose last selected
Later move them all wrong
Greets Daan
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Chape generator no longer equal
Post by Mattotone »
its a bug in your version it seems to be cured in the next release, (well seems to be cured )
Matt
daantas
Post by daantas »
Ok Thanx!
