Hello!
I use artnet with Madrix, as well as Jinx! I'm familiar with setting it up, but I just cannot get any output with freestyler.
My computer I.P. is 192.168.1.101 subnet 255.255.255.0
My Artnet Node is a ColorDreamer Titan 16 universe.
The node IP is 192.168.1.100
Subnet 255.255.255.0
I cannot change net or subnet values.. they default at 0
I put the Node Address in as the Broadcast address, correct?
then nothing!
output 1 on my node is universe 0, 1=2, 2=3, etc... Though I've tried every possible combination.
It works fine with Madrix, but will not work with Freestyler... any ideas?
Thanks so much!
Artnet Seems to have no output
- Just started using FS
- FreeStyler Version: rev i
