LaluceNatz 18LED Par Lights
AudioCraZ
Post by AudioCraZ »
For those looking for a profile for the LaluceNatz 18LED Par Lights, here you go. These are the cheap RGB lights you can pick up on Amazon. There are 6 channels, and they break down as the following:
1 - Master
2 - RED
3 - GREEN
4 - BLUE
5 - STROBE
6 - Color Effects
For (5) STROBE, when you have 1+(2-3 or 6) up, you can set (5) STROBE at values 1 (1 flash every two seconds) to 100 (3 flashes every second) with 10 percentage increases (5@1, 5@10, 5@20, etc to 5@100). 5@100 to 5@255 are the same speed.
For (6) Color Effects you only need 1@255. It breaks down to the following:
6@1-6@7 - RED Full
6@8-6@15 - GREEN Full
6@16-6@23 - BLUE Full
6@24-6@31 - YELLOW (RED Full + GREEN Full)
6@32-6@39 - CYAN (BLUE full + GREEN Full)
6@40-6@46 - MAGENTA (RED Full + BLUE Full)
6@47-6@49 - WHITE (RED Full + GREEN Full + BLUE Full)
6@50-6@66 - RED/BLUE Flash (Siren lights. Alternates from Red to blue, with speed increase 6@50 being slowest to fastest at 6@66)
6@67-6@82 - Color Hard Cycle (RED, BLUE, GREEN, YELLOW, CYAN, MAGENTA, WHITE. with speed increase 6@67 slowest)
6@83-6@100 - Color Fade Cycle (RED, BLUE, GREEN, YELLOW, CYAN, MAGENTA, WHITE. with speed increase 6@83 slowest)
6@101-6@255 - Same as 6@100
The attached ZIP has both the profile and the GIF image. Enjoy!
18LED-Par-Light.zip
(5.22 KiB) Downloaded 265 times
betougalde83
Re: LaluceNatz 18LED Par Lights
Post by betougalde83 »
Thnks Bro
elijahgoldmusic
FreeStyler Version: 3.6.51
Twitter: N/A
Instagram: elijahgoldmusic
Post by elijahgoldmusic »
Thank you! I have set up my lights and they work great! I can’t seem to figure out how to use the 5th and 6th channels though. I have the master and colors working with my midi controller but I see nowhere on how to adjust channels 5 and 6. Any suggestions?
Return to “Generic”
