Coemar samurai Topic is solved
BigBamg
Coemar samurai
Post by BigBamg »
i need the fixtures (or the user manual to create it) for Coemar Samurai 1200...
thanx
Re: Coemar samurai
Channel Function
1 pan
2 tilt
3 shutter
4 colour
5 gobo
6 iris
7 dimmer
8 lamp on/off
Thats the best I can find
set that up then use the sliders when you worked out what your light can do according to the dmx values then you can fill it out...
BigBamg
Re: Coemar samurai
Post by BigBamg »
thanx for the help.
do you know the value for the 8 channel? lamp on/off and reset??
when the fixtur is complete i'll post it for other users
Re: Coemar samurai
nope thats all i could find sorry try it then work it out on ur own light
BigBamg
Re: Coemar samurai
Post by BigBamg »
I just published a post with fixturs for coemar samurai 1200, but there are some flows, listed in the post too.
viewtopic.php?f=23&t=4065
- the colors are not perfectly match
- I have not entered the gobo shapes, but only progressive number
- There are two controls named shutter, but obviously only one is the shutter, and the other is the dimmer
- i haven't found the lamp on/off an all others lamp function (reset....)
- fixture picture is not corresponding exactly
i named the fixture samurai 1200 inc.fxt, I hope to update it as soon as possible.
