Daslight DVC2 512
Jaykie
Daslight DVC2 512
Post by Jaykie »
This is from the old forum
LJ Phoenix
Hi!
Is this interface supported by Freestyler? if so, is there a trick to make it work as for now I have not been able to use it.
Have been trying to use Virtual Controller 2 but Freestyler would be closer to my needs.
Thank you.
Dj Support
when u set up freestyler to work with a specific interface is the device in the list if it is it will work if it isnt it wont!
LJ Phoenix
Well, I kind of figured that out.
I was still hopping that it would work on compatibility basis with the Sunlite 2006 interface.
I was probably mis leaded by an old message on the forum.
Thanks for your message though.
Julien.
DJ Support
send a request to add the device using the bug report system im sure it will probably get added http://fs.djsupportonline.com
LJ Phoenix
Thanks for the tip, I'll do that.
For now I'll keep on playing with my velmann
Cheers,
Julien.
Return to “DMX Interfaces”
