Problems with chase patterns Topic is solved
simmarn
Post by simmarn »
Hey! Im running freestyler with a uDMX adapter. After I updated the software to the newest version, I got problems with my chases. I use lots of Par cans to do chase patterns with. I use the intensity channel to turn them on and off in a pattern and program this to a submaster, Later I use the submasters to make a cuelistbutton. It works fine when I'm programming the chases to a cuelist but when I'm trying to use it in playback as a cuelist button, it won't work as it should.
say for example I have 10 par cans and make a chase with the intensity from the left to the right. When I turn it on, it starts flashing in a sequence as it should but when I turn it off, the last par can that was light up continues being on (full intensity) and when I try to run the chase again, That light will always be on and after a few stops and play, all light will be on with full intensity and the chase doesnt do anything at all.
anyone having a similar problem? It worked fine with the older version of freestyler.
Best regards
Johan
Sweden
