Problem with stairville led par 56 Topic is solved
brunogomes
- FreeStyler Version: 3.6
Hi, this is my first time working with Freestyler. I configured uDMX without problems and added the fixture, but I can not get it to work on led par 56. When I turn on the Lamps, the projector does not show any changes. I set it back on channel 1 (1 of 12). Thanks for your help.
- FreeStyler Version: 4.1.7
Re: Problem with stairville led par 56
Are you able to test another light to be sure your DMX interface (uDMX) is functioning correctly?
I found a Stairville LED PAR 56 that has 5 channels. I've attached the User Manual. Please review the manual to see if this is your instrument.
If this is your instrument then:
1. Make sure the Auto/Music switch is set to Auto
2. Make sure DIP switch 8 is set to OFF
3. Make sure DIP switches 1 through 7 are set to the same address as you specify when you add the fixture to Freestyler
4. In Freestyler set the Mode channel (the first channel) to 0. This allows DMX control of the RGB lamps
Hope this helps. If not then please export your fixture file and post it here.
Stairville LED PAR 56.pdf- (504.39 KiB) Downloaded 40 times
