Fixture for Lixada Moving Head Topic is solved
djmarcello
i'm searching for fixture for Lixada Moving Head.
http://www.ebay.de/itm/2x-Moving-Head-1 ... rkt%3D1%26
Is there someone, who has it?
- FreeStyler Version: 4.1.7
Re: Fixture for Lixada Moving Head
Please post either a link to the user manual or a PDF of the user manual as an attachment
*johny*
Hello
i also need this Fixture.
Atteched you will find a list of the channels.
Attached is a first attempt
If you can supply more information:
- channel 6, what does DMX values 240-255 actually do
- channel 11, details as to DMX values 8-255
- channel 13, details about Auto and Sound
macros and/or custom sliders could be defined that may make using the fixture easier.
Please test and provide feedback.
Lixada_Moving Head.pff- (19.67 KiB) Downloaded 785 times
APC40DUB
Yes Rod, it work great for me!! I DJ reggae club. Thanks Peace!! APC40 DUB
Crrispy
- Bug Zapper...
Thanks for this, works fine for 4 Lixada's I bought recently
Just have to figure out why blackout doesn't work.
Edit: just had to edit the fixture and define channel 6 as shutter, now works perfectly fine.
tankfokke
- FreeStyler Version: x2
- Twitter: https://twitter.com/tankfokke1
- Instagram: @fokkegnodde
rod mine not working.how to fix
KnightyM92
- FreeStyler Version: 2
- Instagram: @MKProductionsco
Rod_Horning wrote: 24 Apr 2017, 11:25 Attached is a first attempt
How can i get a copy of this fixture?!
You may download it from my post (in this thread) dated Apr 24, 2017
Merom
- FreeStyler Version: 4.0.0
Hi! I use also Magic 3D Viewer. Is for the Lixada Moving head also a 3D model what I can use in Magic 3D?
- Jarno
- Jarno
Crrispy
- Bug Zapper...
Here is a small fix replacing the version I already modified some time ago.
Lixada_Moving Head.zip- (390 Bytes) Downloaded 136 times
