Martin Mania SCX700
PWES
Martin Mania SCX700
Post by PWES »
Let me know if you find any problems with this, and I'll be happy to change it ! :fs:
Mania SCX700PW.pff
Gobo's on a previous one i found were wrong for the 700, as were the lamp/ dimmer settings, so this one should be better
(112.13 KiB) Downloaded 69 times
oly77
Re: Martin Mania SCX700
Post by oly77 »
This features didn't correspond to the SCX700. I cannot edit it with fixture creator.
Did you have an update of it?
Thanks,
Olivier
msh-wilms
Post by msh-wilms »
Ich habe das selbe problem... der SCX 700 lässt sich nicht updaten... bitte um eine schnelle Hilfe
Post by Jan_K »
Hej Folks
As the SCX700 can't be edit then I have made a new SCX700 fixture based on the SCX600.
It is a not tested version so please test it and modify it so it works.
And please upload it when you have it working.
Martin_Mania_SCX700.pff
(232.7 KiB) Downloaded 38 times
Return to “Martin”
