Chauvet ColorPalette PFF anyone? Topic is solved
MCreel
Post by MCreel »
I am looking for the .pff for the Chauvet ColorPalette.
Does anybody have one of these or know where to get one?
Re: Chauvet ColorPalette PFF anyone?
MCreel wrote: or know where to get one?
Yes from Fixture Creator...
lightingtech88
Post by lightingtech88 »
Just want to point out that I'm new here, but have been using Freestyler for a long time. Been creating a lot of Fixtures and if you or anyone else has any requests, I'll see what I can do for you.
Now, here is the COLORpalette file you requested. I included a picture as well. Here are the instructions on how to install the file and find it in Freestyler.
Note: These instructions are for a Windows XP computer. If you did not modify the freestyler program folder, you should not have any problems.
Click Start> My Computer> Local Disk (C:)> Program Files> Freestyler> Fixtures.
From there, Extract the files from the ZIP folder and copy/paste both the Fixture File and the GIF picture in the Fixture Folder.
Now open Freestyler. Click Setup>Add/Remove fixtures. Go to the Chauvet File and the COLORpalette should be there. You should know what to do from here. ;)
Anyone who owns this light knows the confusing DMX configuration. Through dmx channel 1, you choose if you want 6, 9, 15, or 24 dmx channel mode. Also channel 1 has internal programs built in.
So this is what I did, I made a set of Macros for Channel 1. Go to the Macros Palette in Freestyler, and from there you can choose what channel mode you want, or choose what internal program to run.
Easy as 1,2,3.
Any questions, just ask! :)
~Jeff
Hi Jeff I've removed your file please post this as an EXPORTED fxture file in the Fixture downloads forum area with an exported fixture all the image files and information that makes the file is saved into one and with just one click of the downloaded fixture file will add all the information and fixture to FS's list sorry for doing that but its much easier for everyone thanks, DJ Support
Reason: removed file
