Ekho PAR 64
darennaylor
Ekho PAR 64
Ekho PAR 64 LED RGB can. Similar to Beamz version
Ekho Par 64 LED.pff- (4.56 KiB) Downloaded 124 times
- FreeStyler Version: Beta
Re: Ekho PAR 64
Hej.
I just had a look on you fixture and when I try to open it then I get an error on invalid parameters.
- FreeStyler Version: 4.1.7
Re: Ekho PAR 64
The Strobe, Intensity and Iris channels have incorrect values.
Total channels is set to 6
Strobe channel is set to 251 (low value is set to Spe)
Intensity channel is set to 128
Iris channel is set to 255
Also, CT0, Frost, Second Frost, and Prism Rotation are set to channel 0.
I do not know if this is a Fixture Creator issue or the way the fixture was defined.
I edited the fixture. The attached version imported to my system without error.
