Need me GIOTTO SPOT 1200gsm fixture. Manual for this is: https://www.techni-lux.com/files/docume ... manual.pdf
I do not know how to adjust the color and gobo.
GIOTTO SPOT 1200 sgm fixture ? Topic is solved
- FreeStyler Version: 4.1.7
Re: GIOTTO SPOT 1200 sgm fixture ?
This is what I have so far. It should work(all functionality can be used via the standard sliders located in the upper right hand side of Freestyler) but I have not yet added pictures for the gobo wheels and some macros to make it easier to use. Please test this and provide feed back.
I will continue to develop the fixture and will post update versions.
Please note that the colors are a guess. I used what is in Freestyler but they may not match the color produced by your instrument. If you can provide the DMX value and an actual color I will update the fixture.
After you select the instrument you will want to click on Window All.
Updated fixture (3/24/2017)
Second color wheel added to control the filters (channel 15)
Macros added to control Strobe (channel 8 - on off controlled by the Lamp window) and Prism (channel 11)
Gobos added (Gobos window) - Channel 7
Note - no pictures of the gobos were supplied so the GIFs reflect the chart on page 24 of the manual
Custom sliders added to control
GOBO rotation (channel 10),
PRISM rotation (channel 12)
LENs selection (channel 14)
After you select the fixture click on Window All. You may need to move the windows around in order to see all 8 windows.
Please test this fixture file and provide feedback.
djgorandj
This is my version, gobo pic not real. Collor is ok, rotation and other funcion ok. Shortly testing your fixtures.
