Hi showman,
Is there someone to use this fixture ? 14CH, 6gobos and 9 color wheel.
If nobody, I'll try to get the gobos pictures.
Sylvain
BRITEQ BT-70LS
- FreeStyler Version: 4.1.7
Re: BRITEQ BT-70LS
Please try this and provide feedback.
After selecting the fixture you will want to click on Window all. You may need to move the windows so that all of the windows are visible.
DO NOT USE THE CUSTOM SLIDERS. In Freestyler 3.6.37 use of these custom sliders will cause Freestyler to immediately close. This is a bug and has been submitted to the bug forum.
BriteQ_BT70LS_14.pff- (106.32 KiB) Downloaded 26 times
Re: BRITEQ BT-70LS
Attached is an updated fixture file.
I replaced the channel 14 custom sliders with macros.
This version, at least on my system, does not cause Freestyler to close when you use the custom sliders.
When you click on Windows All you should see:
Beam
Colors
Gobos
Lamp
Macros
custom sliders
pan/tilt
When you have time please give this version a try. Your feedback will be appreciated.
Rod
Beam
Colors
Gobos
Lamp
Macros
custom sliders
pan/tilt
Rod
