Chauvet cubix 1.0
Kevvyb2008
Chauvet cubix 1.0
Post by Kevvyb2008 »
Has anyone done a fixture for the Cubix 1.0? Or is it possible to do so?
http://www.chauvetlighting.co.uk/produc ... ev_01a.pdf
FreeStyler Version: 4.1.7
Re: Chauvet cubix 1.0
Post by Rod_Horning »
It is possible. If no one posts a fixture file I can make one for you if you would like.
Give this a try. Be sure and click on Window All after you select the device in Freestyler.
Please provide feedback.
Chauvet_Cubix.pff
(82.86 KiB) Downloaded 16 times
Post by Jan_K »
There is also a cubix in the complete library but it may be a 2.0
http://www.freestylersupport.com/fsforu ... =23&t=4528
Jan
I just discovered the existence of the library the other day. It might be helpful to include a link the blue First Have You Tried? box (above).
Return to “Chauvet”
