Microsoft Office when running Freestyler
Ariajazz
- Just started using FS
- FreeStyler Version: 3.6.3
Every time I run Freestyler the software attempts to run a sort of MS office installer. If I cancel it appears again several times until it disappears and Freestyler GUI opens. This happens not only when running the program but when trying to use some of its features. I'm completely new to this program so I don't know anything about it, but it seems to me as a weird behavior.
- FreeStyler Version: 4.1.7
Re: Microsoft Office when running Freestyler
Could you post some screen shots? Freestyler does use Microsoft's DotNet and will see a request to install it.
Ariajazz
I don't know exactly how to upload an image. Microsoft .NET Framework is alrady installed, latest version compatible with Windows 10. I is asking for MS Office 2013 installation
Ariajazz
The problem is not how to take a screenshot, I know how to do it, The problem is how to upload the picture, I can not find a way or a link for uploading the file. What I'm thinking of is that I deleted the remaining files for the OFFICE installation folder. Now FREESTYLER is searching for those files in that folder that is empty. I'm gonna try to reinstall both OFFICE and FREESTYLER and see what happens.
Thanks a lot
Thanks a lot
Sorry, I misunderstood. Near the bottom of the post page you should see a box that says Full Editor & Preview - its next to the Submit box. Click on it. This should provide two tabs: Options Attachments. Click on Attachments. Now you should see a box that says Add files.
Ariajazz
Problem solved. It was a lack backup files for Office installation. I reinstalled all programs and and everything is working OK.
