pulse par 36 fixture Topic is solved
Kevvyb2008
Post by Kevvyb2008 »
Can anyone point me in the right direction for the fixture for a pulse par 36 can?
Searched high and low on here for something similar but not sure what I am looking for.
tried different fixtures but to no avail.
Thanks in advance.
Kev. :fs:
FreeStyler Version: 4.1.7
Re: pulse par 36 fixture
Post by Rod_Horning »
Kevvyb2008
yes...yes it is? is there a profile for this 5 channel?
User_Instructions_COMPACTPAR.pdf
Attached is a PDF of the user manual. Have fun reading it :!: ;)
I will create a fixture for you to test. Might take a while as I need to read and understand this fixture.
Kevvyb2008
Thank you,have read the manual and set my pars accordingly,just need the fixture for it as I cant seem to find a similar one.
Pulse Compact Par 5chan.pff
This is my attempt for 5 channel mode.
Be sure to CLICK on WINDOW ALL after you select the fixture.
You should see The Colors window, the Macros window, and an untitled window which is the custom sliders.
This fixture, as I understand the manual, DOES NOT HAVE a dimmer channel. I have not encountered this before.
5 channel DMX mode is documented starting on page 13 of the manual. The Macros window will set DMX values for Channel 1. The Custom Slider window will set DMX values for channel 5.
Anyway, give it a try. I will appreciate any feedback and am willing to modify the fixture if it will help you. I will try to answer any questions you may have.
Good luck!
Kevvyb2008
Thank you so much...going to try it now!!
